Just bought a 2005 Honda TRX 400EX
Any information or recommended upgrades? The machine is stock and I just bought manual, air filter, oil filters, brake pads and needing rear tires.
What tires are recommended for snow and dirt track riding?
I have seen sale ads stating "jet kit". What is the recommended jets? I don't know what a jet kit includes, but the dirt bike I have uses three main jets for the changes I need do to temperatures. Do I need anything more than just three main jets for the quad?
Any information would be great. Thanks. Lots to read now on the forum with this new machine, but information given will reduce my searches. Thanks
The jetting currently will be good for a stock bike, If you plan on putting a pipe or filter on, or build the engine you will need to jet accordingly check out www.exriders.com for a ton of 400ex information.
I had a set of Razr mx I liked alot. In my opinion jet kits are a waste of money, some pipes come with jets and if they don't go to exriders and learn how to read plugs then you only need to buy the jets you need. Also on that model there was a recall on a spring problem somewhere in the tranny that would allow the bike to go into reverse while riding in I think 5th. When I bought mine it had an x stamped into the case right above the shifter to mark that it has been taken care of. You can call a dealer and they can run the vin to see if it's been done.
I figured the entire jet kit was a waste. I only use 3 jets for my crf450R. Now I came across someones post about Klein vs. other brands of jets. The numbers are not the same across the board. How do you know what brand you originally have? What is stock on a Honda. With my dirt bike, I assumed it was Klein brand and now I am unsure. Nothing I have seen in the service manual has this information. I do have a service manual on order with the 400ex, but not sure what details will be there.
I will look into the tires. Thanks for the information given so far. I didn't want to upgrade the pipe. So many people on the dirt bike say pipe up grades are not worth the money and mostly power is lost due to jetting being wrong. I thought I read the factory settings were not correct. Now I can't find those post again! ARG!
This is now confusing me. I found this chart...
Width------Kehein # -- DynoJets # -- Mikuni #
0,0350---- 92,5--------- 92----------- 86,3
0,0360---- 95----------- 94----------- 88,1
0,0370---- 97,5--------- 96----------- 90,0
0,0380---- 100---------- 98----------- 91,9
0,0390---- 102,5------- 100---------- 93,8
0,0400---- 105--------- 102---------- 95,6
0,0410---- 107,5------- 104---------- 97,5
0,0420---- 110--------- 106---------- 99,4
0,0430---- 112,5------- 108--------- 101,3
0,0440---- 115--------- 110--------- 103,1
0,0450---- 117,5------- 112--------- 105,0
0,0460---- 120--------- 114--------- 106,9
0,0470---- 122,5------- 116--------- 108,8
0,0480---- 125--------- 118--------- 110,6
0,0490---- 127,5------- 120--------- 112,5
0,0500---- 130--------- 122--------- 114,4
0,0510---- 132,5------- 124--------- 116,3
0,0520---- 135--------- 126--------- 118,1
0,0530---- 137,5------- 128--------- 120,0
0,0540---- 140--------- 130--------- 121,9
0,0550---- 142,5------- 132--------- 123,8
0,0560---- 145--------- 134--------- 125,6
0,0570---- 147,5------- 136--------- 127,5
0,0580---- 150--------- 138--------- 129,4
0,0590---- 152,5------- 140--------- 131,3
0,0600---- 155--------- 142--------- 133,1
0,0610---- 157,5------- 144--------- 135,0
0,0620---- 160--------- 146--------- 136,9
0,0630---- 162,5------- 148--------- 138,8
0,0640---- 165--------- 150--------- 140,6
0,0650---- 167,5------- 152--------- 142,5
0,0660---- 170--------- 154--------- 144,4
0,0670---- 172,5------- 156--------- 146,3
0,0680---- 175--------- 158--------- 148,1
0,0690---- 177,5------- 160--------- 150,0
0,0700---- 180--------- 162--------- 151,9
0,0710---- 182,5------- 164--------- 153,8
0,0720---- 185--------- 166--------- 155,6
0,0730---- 187,5------- 168--------- 157,5
0,0740---- 190--------- 170--------- 159,4
0,0750---- 192,5------- 172--------- 161,3
0,0760---- 195--------- 174--------- 163,1
0,0770---- 197,5------- 176--------- 165,0
0,0780---- 200--------- 178--------- 166,9
0,0790---- 202,5------- 180--------- 168,8
0,0800---- 205--------- 182--------- 170,6
0,0810---- 207,5------- 184--------- 172,5
0,0820---- 210--------- 186--------- 174,4
0,0830---- 212,5------- 188--------- 176,3
0,0840---- 215--------- 190--------- 178,1
0,0850---- 217,5------- 192--------- 180,0
0,0860---- 220--------- 194--------- 181,9
0,0870---- 222,5------- 196--------- 183,7
0,0880---- 225--------- 198--------- 185,6
0,0890---- 227,5------- 200--------- 187,5
I assumed I had Kehein jets in my Honda CRF and it was a 170. I bought 168 and 172 jets. At work right now and I will need to verify the manual and the jetting chart. Looking at this information, the stock jetting is Dynojets? Is this true for all Honda's. If I recall, the manual did call out the temp range and suggested the 168 and 172 jets. Kehein doesn't even make this number I take it. Am I reading into this correctly?
Have you guys tried the removing the choke performance trick? ATV Technical Article, Honda 400EX Carburetor Choke Removal Instructions
They also have a good understand jetting post. http://www.atvriders.com/articles/jetting.html
Reading the chart is confusing with the 172,5. I do know the jets I have for my bike are 168,170,172. Looking at the chart made me feel like the jets are Dynojets. I am getting a twin air filter for it and should be good enough for what I am using the quad for. I know it will not pull like my 450R.
Thanks for the input!
