skid plates ?
Old May 24, 2011 | 12:40 AM
DIABL0's Avatar
Default skid plates ?
what are the must have skid plates? 300ex 2002
Old May 25, 2011 | 02:30 PM
jgar's Avatar
You really have to have a good aftermarket swing arm skid plate. Then if you want you can do the belly skid plate.
Old May 25, 2011 | 02:36 PM
DIABL0's Avatar
what would be a good brand...DG, AC or some other brand?
Old May 25, 2011 | 02:43 PM
jgar's Avatar
I have pro armor and they have held up well on my old 300ex and the 400ex I now ride.
Old May 25, 2011 | 05:09 PM
DIABL0's Avatar
is there a specific pro armor for a 300ex or would one for a 400ex work?
Old May 25, 2011 | 06:05 PM
95wolv's Avatar
A arms are different sizes on 400 and 300ex, for the best protection, go with the entire kit, A arms, belly and swing arm. Any one of those can end your ride if damaged, why have a belly plate when you wrap your A arm around a rock, and tear loose a lower arm? Or not have a swing arm plate and have a rock come up and break your chain or crack your sprocket, ride over. Plus the added benefit of being able to "slide" over rocks and logs that would have hung up on an a arm or swing arm, now with it all covered, you can let the weight of the ATV glide you over stuff that would have grabbed your frame and stopped you.
Old May 25, 2011 | 06:08 PM
DIABL0's Avatar
are there kits that will provide all the plates or do i have to buy them separately.
Old May 25, 2011 | 06:31 PM
95wolv's Avatar
Ricochet offers full kits, most others do too, often you save a little money with the kit versus buying everything seperate, check eBay as well, some nice full kits on there too.
Old May 25, 2011 | 11:21 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
You should definitely go for the thickest aluminum rear swingarm skidplate you can find, it will save your sprocket and brake disc from disaster if you hit something (or land on it) I had one made by PRM that took a hell of a beating and protected swingarm extremely well
You might also consider a plastic skidplate (Maier made one in the mid to late 90's that was very durable) since the 300EX is lightweight by comparison.
Same for A-Arm guards, consider plastic (again Maier) unless you are really going to go mountain goating on your 2wd 300EX
I have used Suzuki (Yoshimura) and Ricochet skids on my various Utility/4WD rides, and they make a very good product
Old May 25, 2011 | 11:30 PM
No Ruts, No Glory
http://prm-atv.com/MN.asp?pg=product...ic=235&from=44
Glad to see that PRM is still in business...I don't know what's up with the two piece construction, the one I bought back in 1994 was a big solid chunk of aluminum
Honda TRX300EX Skid Plate | Maier USA
I may have been mistaken about the plastic A-Arm covers, now that I think about it, but this skidplate is pretty durable, lets you slide over a lot of stuff, and is on sale!
