400ex gas leak
Old Jul 18, 2011 | 10:34 AM
Ty Coulter's Avatar
Default 400ex gas leak
I have a gas leak below the chain and back brake disc. I have no idea what it could be! any help is appreciated.
Old Jul 18, 2011 | 03:05 PM
budedm's Avatar
Sounds like the drain hose from the carb is leaking. Which means the screw that opens up the float bowl drain is bad. Loosten it and tighten it a few times. If that doesn't work, replace it. It's on the left side (as you sit on it), at the very bottom of the carb. It's kind of recessed.
Old Jul 19, 2011 | 04:56 PM
95wolv's Avatar
More than likely, you have a bad needle and seat, which overfills the carb bowl and causes it to drain out the overflow hose, the screw is for manually draining the carb, which can come loose, but that rarely happens, usually it is stuck shut, and a beeotch to open. the overflow is a little hole connected to the same drain line, and will bypass the screw hole drain in case of a bowl overfilling, so it doesn't end up flowing into the cylinder and hydrolocking your motor.
Old Jul 20, 2011 | 11:01 AM
Ty Coulter's Avatar
How do i fix it then? I just got the carb rebuilt last week!
Old Jul 20, 2011 | 08:46 PM
jgar's Avatar
Return it to who ever rebuilt it and tell them what its doing.
Old Jul 21, 2011 | 01:02 AM
95wolv's Avatar
was it a total rebuild with new needle and seat? sometimes they are not included in a rebuild kit, and must be bought seperately. Who rebuilt it? a shop, a mechanically inclined buddy,or a dealership? I would ask them exactly what was "rebuilt" or if they just took it apart, sprayed it out and reassembled it.
exmotocrosser
Sep 13, 2019 06:12 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
