400EX oil
Old Mar 14, 2001 | 06:32 PM
Danimal's Avatar
Honda dealership said use honda p/n yada yada oil, local shop said SEA 10W40. Who do I listen to?
Old Mar 14, 2001 | 10:08 PM
jmann440's Avatar
take your pick.......just change the oil and filter often......
Old Mar 14, 2001 | 11:23 PM
pudjumper's Avatar
GN4 works great.
Old Mar 15, 2001 | 11:29 AM
jmann440's Avatar
i've been useing gn4 and i add 1 oz. of this product called energy release.i've been useing this product in my quads since 92 and it makes a huge difference in wear on my machines,especially
in cam and piston wear...i'll swear by this stuff.it's designed not to affect clutch mechanisms too.i will continue to use it as long as they make it......www.energyrelease.com
Old Mar 15, 2001 | 11:50 AM
400EXPILOT's Avatar
By Honda ,you cant go wrong!!
Old Mar 15, 2001 | 09:36 PM
shook's Avatar
I run golden spectro and have been for years in the testing it out performed the gn4 never had a motor failure yet.I do recommend it be changed often these motors love to chew up rockers and the cams that metal go somewhere.But i agree gn4 is not bad oil and will work fine but honda dont make oil they make motorcycles somebody makes it for them.I dont recommend fully synthetic i have noticed clutches chattering using full synthetic a blend would be better.
Old Mar 15, 2001 | 09:46 PM
Danimal's Avatar
What about NAPA brand SAE 10W40?
Old Mar 15, 2001 | 10:04 PM
99500scrambler's Avatar
I would not use an automotive oil in an atv or motorcycle. They do not have thermal and viscosity resistant addatives in them like the honda oil and other oils made for small air cooled four strokes. I just bought oil and filter for my first breakin service for my new 400ex and I got the honda oil. It is not that expensive. I bought a gallon jug for around $13. I would rather pay a few extra bucks at service time and not have to wory abought internal part failier due to me beeing to cheep to use correct lubricants. That is probobly why it cost me $35 to change oil in my truck every 3000 miles. Mobil 1 is $5/quart.
Old Mar 16, 2001 | 02:28 PM
Wicked400EX's Avatar
I use Mobile 1 tri synth 15-50 i've had many problems in the past this works for me. safe 4 wet clutches. check out mobiles web site.
Old Mar 17, 2001 | 12:47 PM
Buckeye400EX's Avatar
I've used Valvoline 10W40 for over 15 years. I've never had an engine failure. I do use the Valvoline Synthetic Blend now. If you maintain your ride at the scheduled times, you probably won't have problems regardless what you use, but I wouldn't buy NAPA brand oil.
