2001honda 400ex
Old Apr 1, 2012 | 10:20 AM
daniel400's Avatar
Default 2001honda 400ex
Why does my 2001 honda 400ex cut out on top end?
Old Apr 1, 2012 | 01:14 PM
woodsidewarrior's Avatar
Your main jet my be clogged a bit or even to small
Old Apr 1, 2012 | 07:30 PM
daniel400's Avatar
thank you but I cleaned the carburetor thought it was timing but I'm pretty sure its the cdi box
Old Apr 2, 2012 | 09:52 AM
95wolv's Avatar
need more info....have you changed anything? smaller rear tires, opened up the air box, or added a pipe/muffler? have you changed the front or back sprocket to a different size? Honda has a pretty low rev limit, if you open up the air box, or pipe it, or drop the gearing or tire size, anything that lets it rev more or easier, you will bounce off the limit, and it will cut out and surge on the top end. I had to put a +1000 rpm cdi on both my sons hondas, his 300ex and 400ex, when the intake and exhaust was opened up, revved so much better, but was constantly hitting the limit.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
