300EX Parking Brake
Old Mar 18, 2001 | 10:16 PM
jakec500's Avatar
Just bought a 1999 300EX but the emergency brake dosn't work. Rear braks work great but when I pull the parking break cable I see brake fluid comes out the left side where the parking break cable lever are goes into the caliper. Any suggestions. Does this mean I have to get a new rear caliper. I there some kind of adjustment?
Thanks, Jake
Old Mar 20, 2001 | 10:23 AM
REDTEAM's Avatar
I bought a 2001 300ex and mine didnt work either, i had 3 friends also buy brand new 300ex and theres didnt work either, just put it in 1 st gear and use that as your parking brake
Old Mar 20, 2001 | 11:33 AM
trapperb1's Avatar
The parking brake is something that Honda never did get "right." The same basic set-up from back in the '80's and it didn't work then and it doesn't work now. Just don't use it. In fact, take the whole parking brake cable assembly off, put on an EZ pull clutch lever and a block off plate on the brake and pretend it never even had one.
Old Mar 20, 2001 | 10:10 PM
dirtclog's Avatar
i have a 2000 300ex and mine never worked well either...i just leave it however it is now. but i wanted to post about 2 things...don't transport your quad in your truck with it in gear to keep it from moving around...i used to do it all the time and was recently advised not to...(messes up the gears possibly)..also, mine doesn't leak any brake fluid like you said yours did...i would get block off kit like prev post suggested.
Old Mar 20, 2001 | 10:30 PM
hondakid15's Avatar
my 99 300ex s parking brake never worked, small price to pay for a good quad.
Old Mar 21, 2001 | 04:26 PM
3o0eXpAuL's Avatar
Mine never worked i just put it in 1st gear when i want it to stay where i put it.
Old Mar 21, 2001 | 05:22 PM
2fiftyX's Avatar
I don't think I ever even tried to use it. So I just took it off, I still need to look for a block off plate. Where can I find one and how much do they run? Thanks!
Old Mar 21, 2001 | 09:49 PM
TRAIL's Avatar
Hy-tech atv sells cascade block-offs for 8.95
Old Mar 22, 2001 | 12:04 PM
Sportax300EX's Avatar
Just bought a new 2001 300ex, mine doesnt work either, my dealer told me that i have to adjus it after every ride. Don't use first gear as your parking brake either. Your tranny will not make it in the long run.
Old Mar 22, 2001 | 06:04 PM
puddding's Avatar
my 92 250x doesn't mind the 1st gear park brake...............just don't leave it in gear on the truck to hold it there......if you tie it on properly she won't go anywhere
the park brake on my 350x has been removed as well
