400ex smokes when first started.
Old May 26, 2012 | 08:38 AM
Mr_Burrows's Avatar
Default 400ex smokes when first started.
My 400ex smokes when I first crank it everyday untill it warms up. Is this normal? I just recently rebuilt the engine and I was having carb problems and now this is the only issue im having.
Old May 27, 2012 | 10:55 AM
Doctorturbo's Avatar
GOT BOOST!
What kind of smoke? Oil smoke?
If so did you rebuild the head? Did you mic the guides and valves? If so what was the clearance? Did you put new guide seals on it?
Old May 27, 2012 | 04:17 PM
jgar's Avatar
Doctorturbo is asking the right questions. Sounds like valves.
Old May 27, 2012 | 05:00 PM
Mr_Burrows's Avatar
I had the valves installed at a machine shop, and I did have new seals installed. the smoke smells more like fuel.
Old May 28, 2012 | 12:58 AM
GOT BOOST!
Well that could be a lot of things. If it's fuel the floats could be set a little high or trash in the seat or even a little nick in the seat so when it sits it runs a little gas in the intake and into the head and cylinder.
Does the oil smell fuelly? Does the engine use oil?
The first thing you need to figure out is if it is burning oil or fuel. I don't really know how to tell you how to do that other than smelling it.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
