400ex K&N powerlid worth it?
Old Jan 8, 2013 | 09:00 PM
quadtrx400ex's Avatar
Default 400ex K&N powerlid worth it?
K&N POWERLIDS from Tousley Motorsports
Thats what i am looking at....is it really worth the $127?? how much power would i actually get?? would a K&N filter (not the lid) be a better idea? thanks!
Old Jan 9, 2013 | 01:24 AM
400EXrider02's Avatar
Personally, I've never cared for anything K&N, they are more about looks than function. Their filters let more dirt pass through than any of the quality foam filters out there.
Old Jan 10, 2013 | 05:37 PM
ya iv heard that and my bro has one no probs yet but do u know of any cheap simple ways to gain a little power?
Old Feb 6, 2013 | 02:03 AM
bluegizmo83's Avatar
Real simple and FREE, just take the lid off your air box and drill a bunch of 1/2 inch holes in it or a few larger holes! It will allow MUCH better air flow because the stock air intake tube is really restrictive. Just make sure you drill the holes on the back end of the lid so that the holes are not directly over top the filter just in case water splashes up into the holes. Also, if you ride in wet conditions it would be a good idea to also drill a drain hole in the bottom of the air box too.
Old Feb 6, 2013 | 11:14 AM
budedm's Avatar
This didn't work on my 250X. I found out that air VELOCITY is just as important as air VOLUME. Without the holes, velocity is much higher so the air is almost forced into the carb, resulting in better performance. But that was a 250X.
Old Feb 6, 2013 | 02:46 PM
Yeah the 250X many be a little different design or something. People have done dyno tests on the 400ex before and after drilling the lid and it did make a different in power. Your not gonna see a 15% gain in power by just drilling your air box lid of course, but it does help.
Old Feb 7, 2013 | 04:54 PM
95wolv's Avatar
I would get the Outerwear kit that velcroes to the top of the open air box, about 30-40 bucks...flows like an open box, but keeps lots of dirt out, and you can even spec waterproof coating to keep the box dry during puddle crossings, a big problem with no lid or drilled lid. You can even get kits tha have you cut out the middle of your lid, and bolt in an aluminum bracket that holds and Outerwear screen, a bit more expensive, but looks great.
r1pilot83
Sep 27, 2015 07:38 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
