ES Question
Old Apr 22, 2014 | 11:46 AM
Tex Prexhurst's Avatar
Default ES Question
I have a '06 tsx350. The electric shift works well unless you rev the engine fairly high while driving. After that, I get three blinks on the gear indicator and it will not shift. Turn it off and back on, and it works fine. It doesn't seem to make any difference which gear I am in, just get the engine revved up, and it won't shift. Three blinks is supposed to indicate a problem with the angle sensor. Could it be simply that it is not installed correctly?
Thanks,
Tex
Old Apr 22, 2014 | 10:38 PM
papa hogg scoot's Avatar
Loved
Community Favorite
does atv have an good battery on it or loose batt cables?Yes its possible angle sensor installed wrong but not common an wouldbe hard to install wrong but an person install angle sensor could have not align flat shoulder up with shaft but not likely tho..bad batt or loose cables,bad angle sensor IMO
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
