400ex helppp!!
Old Jul 26, 2014 | 07:48 AM
Scooter86's Avatar
Knows Old ATV Questions!
You really need to check compression before throwing a bunch of parts at it. Having said that, a new plug is pretty cheap. New or not, they are sometimes bad from the start. While you are at it, I would start inspecting your wiring harness as well.
Old Jul 26, 2014 | 09:34 AM
missouri_400ex's Avatar
I will do that too
Old Jul 26, 2014 | 10:03 AM
What should I look for when looking at the wiring harness
Old Jul 26, 2014 | 11:38 AM
Scooter86's Avatar
I would suspect if you had a wiring issue, you either wouldn't have spark at all, or might possibly blow the starter relay fuse. First I would check any grounds in the system. Even if they look good, I would clean these up so I knew they were making good contact. Then I would check connections for corrosion or dirt infiltration that may be hindering contact. This is a good time to place a little dielectric grease in your connections to keep them happy. You also can check the wires themselves for areas where the insulation is wearing away, kinks, pinches, etc.
A multimeter and good service manual/wiring schematic are essential for tracking down electrical issues if that is truly what you have. It may even be as simple as a bad plug wire.
Old Jul 28, 2014 | 02:09 PM
  #15
Changed plug checked compression all good still not starting.
Old Jul 28, 2014 | 08:04 PM
  #16
Originally Posted by Jaster94
check these things;
1. compression-use a gauge, not your thumb
2. fuel-is the fuel making it through to the cylinder/jug?
3. spark-is it making spark?
i was just looking at my cdi and there a wire missing from one of the holes i cant find a loose wire anywhere its been gone for a while because there was dirt in the hole. What should i do?
Old Jul 28, 2014 | 08:27 PM
  #17
HondaR24's Avatar
Here is a schematic of a 400ex electrical system.what wire is it?[IMG][/IMG]
Old Jul 28, 2014 | 08:29 PM
  #18
https://blu184.mail.live.com/att/Get...UvanBlZw_3d_3d
Old Jul 28, 2014 | 08:32 PM
  #19
believe its the green and white one.
Old Jul 28, 2014 | 08:42 PM
  #20
NOT WHITE AND GREEN im not sure which one do you know?
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
