2004 400ex
Since you have the air box off,try blocking the rear of the carb with your palm to see if it can get a good charge of fuel into the combustion chamber. May help get the engine kicked off. Or simply put the air box and filter back on. Last resort you can give a small shot of ether to get it going on it's on if timing and everything else is ok. Good luck.
Sw00p
Sep 24, 2015 02:50 PM
