TRX 125 Tranny Mods Possible?
Old Feb 12, 2003 | 08:05 AM
dzzy's Avatar
Default TRX 125 Tranny Mods Possible?
Texian Fury: You have too much time and ambition for your own good. Leave the tranny alone as these mods are not worth the money and work. Put your money on fixing what you know is wrong with it, IE. first class top end rebuild. Also if spark plug fouling is a problem, replace the carburator slide needle and the little jet you can see from inside the carb bore (needle jet set in Honda speak), available as a kit from your dealer. the needle jet gets ovaled from the needle sliding up and down in it and will cause rich running, poor idling and regular spark plug fouling. Common problem in mid 80's Hondas, recent models use a hardened , instead of brass needle jet, and I don't see this anymore. If these parts are wore , you won't believe how nice it runs when replaced. Have fun!!
Old Feb 10, 2004 | 01:33 AM
alpine8181's Avatar
i have a 1985 trx 125 and its
low
rev
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
Logan Collins
Sep 5, 2015 08:03 PM
