Need Help.
Old Jul 14, 2001 | 05:10 PM
bigbadlakota's Avatar
If my tire size is 22-11-10 And i go down to 20-11-10 will it hurt anything. Or would I need to change sprokets or something.
Old Jul 14, 2001 | 05:15 PM
fourtraxmike's Avatar
from my understanding about tire size you should not have any problems downsizing the tire. although your to speed will be reduced you will have better acceloration and with smaller tires you will have a lower center of gravity making the handling better
i think
mike
Old Jul 15, 2001 | 07:40 AM
bulldogg's Avatar
Putting smaller tires on is like putting a bigger sprocket on the back, gives it a little more low end and a little less top end, you probably won't notice much difference, if you do and don't like it you can go a couple teeth smaller on the back sproket to give it more top end.
Old Jul 16, 2001 | 11:06 AM
BigGun's Avatar
smaller tires means a smaller gear period, either front or back, more so up front than out back. Dropping one gear up front is like dropping 3 out back, wich is like dropping a inch in tire size. All calculations are made without a calculator of course, But I could make measurements if you like.
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Sassinm1
Sep 30, 2015 04:23 AM
Matt123
Sep 29, 2015 01:29 AM
2many2ride
Sep 27, 2015 04:35 AM
