raptor motor on 250r frame
Old Jul 22, 2001 | 06:07 PM
TitanRacing25's Avatar
Hey I found a raptor motor with electricals and everything to make it run, and a 250r frame with everything i need to roll and then some, would it be hard to make this work? other than motor mounts? Could I use the 250r radiator? or the raptor one? or would it even matter?
Old Jul 22, 2001 | 07:06 PM
mt400EX's Avatar
I dont know but it will be a kewl quad! Take pics if ya do it!!
Old Jul 22, 2001 | 08:27 PM
RedRooster's Avatar
Will you call it a Hamaya or a Yonda?
Old Jul 23, 2001 | 01:20 AM
a hapter lol
Old Jul 24, 2001 | 12:59 AM
Riceburnin's Avatar
sounds cool, i would use the raptor radiator since it was designed to efficiently keep the 660 cool. I really dont know of anything that would make this swap impossible. Some custom fabrication and youll be in. One main problem will be an exhaust for it. That might be a bit expensive.
Old Jul 24, 2001 | 02:57 AM
you guys dont think the motor would be too tallor anything do you?
Old Jul 24, 2001 | 12:00 PM
swytak's Avatar
Measure the motor, or have someone that has a Raptor measure it for you and do the same for the frame. It's possible that it would be too tall but, that's just specualating. I would be willing to post what the Rapot motor dimensions are for you tomorrow.
Let me know.
Old Jul 24, 2001 | 12:23 PM
Riceburnin's Avatar
I am not sure how tall the 660 is. But if it similar to the 400ex motor then it should fit. You might have to actually cut the frame to get the motor in and then reweld it. Sounds crazy but I know people who have had to do that to do swaps in quads.
Old Jul 24, 2001 | 04:18 PM
lonestarbanshee's Avatar
Riceburnin's right, you MIGHT have to cut a little on the frame. If you do, I recommend you cut it at a previous weld spot. Then, TIG weld it, then go over it with a 7013 stick. the tig will make a pretty weld, then the 7013 will make a stronger cap. You might even go BACK over the 7013 with another tig weld, to make it look good! Also, If you do this, I would get the frame powdercoated.. especailly in that sopt! There's a guy that rides with us down here, that handbuilt his own A-Arms... he did a really good job. If you want, go to http://www.quadforce.com, and email him. Ask him what kind of welds he made, and what he used. Afterall, you don't want your frame to break coming off a big jump, or whatever it may be
Old Jul 24, 2001 | 04:19 PM
yeah give me those dementions, I dont really feel like measuring mine because it willtake me a while to find my measuring tape, welding is no problem my dad is a professional welder, I mean he does it all the time, has degees and stuff, he said he can do the exhaust too.
