UNI vents and filter, do i need to rejet?
Old Aug 5, 2001 | 09:53 PM
300EXKING's Avatar
i just put on sOme uni filter vents, and am gettin a white brothers filter, the thing is with jusr the vents i can tell it has a little more power but it kinda bogs down a bit every once and a while. Do i need to rejet? or will it be differnt when i get my filter? Please help
adam
Old Aug 5, 2001 | 10:02 PM
bermbanger's Avatar
Pull the plug. If its brown no white yes.
Old Aug 5, 2001 | 10:07 PM
300EXKING's Avatar
If its brown what should i change my jets to?
Old Aug 5, 2001 | 10:10 PM
Y2K300EX's Avatar
If its brown it is running perfect and doesn't need rejeted. If its white, then its running lean and needs to have the jets increased. Probably go up 1 size on the main, maybe 2 but you can only tell by what the plug tells you.
Old Aug 5, 2001 | 10:52 PM
300EXKING's Avatar
Thanks a bunch for your input..adam
Old Aug 5, 2001 | 11:09 PM
bermbanger's Avatar
300EXKING I think I found something on you. Your name is adam phillips and there is also a guy on here with a nickname of AdamPhillips........why is that?
Old Aug 5, 2001 | 11:38 PM
300EXKING's Avatar
No my name is Adam Philippi
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
black798
Sep 9, 2015 07:42 AM
