BIG BORE KIT WHICH one and from WHO ???
Old Aug 6, 2001 | 04:13 PM
KKKILLER250X's Avatar
I have an 87' 250X and I will be getting a big bore Kit my question is WHO should i get in from , I was leaning towards powrolls 335 kit but I would like to know who makes the best one? I don't want to send my motor out I have someone who will do it I just need the best parts. HERES some INFO.
POWROLL $311.50
78mm Forged Piston, 13:1 - 10.5:1 Compression. Requires re-sleeving. Kit comes with piston, pin, rings, circlips, head gasket and sleeve. 335cc when used with our stroker crank for the 250X & 300EX.
PLUS STROKER CRANK $313.30
Stroke work is done on your good crank assembly. Price includes work only, parts (if needed) are extra.
Old Aug 6, 2001 | 09:17 PM
94DGblaster's Avatar
well, most of the kits from powrol require you to split your cases and machine them to accept the bigger sleeve. FST, and TC doesn't require that. But if you are going to stroke it too, then its not a problem. I plan on installing a stroker crank this winter.
If you are going to sell your 250x why are you concerned with it? I thought you hated it?
Old Aug 6, 2001 | 11:18 PM
NO NO NO I dont HATE my 250X I like it alot but I like 250R's more. I figured that while im waiting I night as well do some mods to it to get MORE POWER!! I know it probably sounds stupid but oh well. I dont mind spliting the cases because I'm not doing it , i didn't relize you had to split the case with the powroll stuff , thanks for that info!
Old Aug 7, 2001 | 05:48 PM
the case has to be machined out bigger to accept the new sleeve. FST and TCs are taper bored. They fit in there, its a little snug, but it works!
Old Aug 9, 2001 | 01:43 AM
kkkiller300ex's Avatar
yea i really dont think your going to do this that sounds like a lot of money if you ask me you will have to work alot to get that stuff id say just sell it and be done with the thing if your even selling it or trading it im not saying its not going to happen im only saying its point less to pay for all that and only have it for a little while right?
Old Aug 9, 2001 | 08:31 AM
cstark's Avatar
I wouldn't waste my money on the "cheaper" stroker crank mod. They heat up your stock rod and stretch it to make it a stroker. Do you really want to run more power on a stretched out stock rod? Not me.
Save yourself the headache and buy an aftermarket rod and stroker crank. It's more money, but way more reliable.
BTW... I snapped a stock rod in my 330. I can't imagine running a weaker stretched rod.
Old Aug 9, 2001 | 01:46 PM
KILLER250R's Avatar
Thank you Cstark and 94dgblaster for the HELPFUL information. Also thank you kkkiller300ex for the incredibly useless information.
Old Aug 9, 2001 | 02:54 PM
ScramblerX's Avatar
kkkiller250x, kkkiller300ex, and killer250r, are the same people??
Old Aug 9, 2001 | 02:58 PM
KILLER250R's Avatar
Ah NO I am KKKILLER250X BUT i changed my name to KILLER250R today so the name KKKILLER250X is no longer in use. kkkiller300ex is a kid that lives down the streat from me.
Old Aug 9, 2001 | 03:14 PM
ScramblerX's Avatar
Oh, I see, just looked a little confusing.
