185S
Old Oct 19, 1999 | 12:24 PM
Bill.Ciliberti's Avatar
Erractic Idle can be one of many things.Check this out first,Make sure the black rubber intake boot between the carb and intake is not sucking air.[leaking]Spray some carb spray on this boot with the engine idling.If the rpms increase,replace the rubber boot.Im betting this is probably your problem.Good Luck------BILL
Old Oct 19, 1999 | 02:58 PM
tbass2's Avatar
My little sister has a little 185S and it runs fine and all but it has trouble idling. Sometimes it does and sometimes it doesn't. I've adjusted the carb once, but then sometimes it would rev up real high and go on it's own. Has anyone had this kind of problem before?
superdizzyboi
ATC 3-Wheelers
Aug 30, 2015 07:22 PM
fourtraxmike
Apr 28, 2005 01:53 PM
robg
Mar 21, 2001 09:05 PM
63tbirdrick
ATC 3-Wheelers
Jan 22, 2001 07:50 PM
garyc660R
Oct 25, 2000 10:59 PM
