400EX Tips
Old Oct 23, 1999 | 09:38 PM
The400EXman's Avatar
anything goes, whatever little tricks, information, or other stuff that you have about the rockin EX will be appreciated. thanks
Old Oct 25, 1999 | 02:48 PM
Cknweasel's Avatar
if its new...a full tube of blue lock-tite will save you money on screws and bolts...also take a wire tie to the silenoid by the battery...mine always hops out of the rubber boot
Tha Crazy Cknweasel '00 400ex..picked up 7-24-99 '85 lt250r..in the making
Old Oct 25, 1999 | 02:57 PM
philzie's Avatar
Use more than 4psi in the tires. I have been running 8. It keeps the wimpy Ohtsu meats from rolling over in hard corners.
Check your rear brake pads often. They wear out quickly.
Phil
Old Oct 25, 1999 | 04:57 PM
norm440EX's Avatar
Watch your clutch cable where it goes between your headpipes. I have a Big Gun system and since the bend is different than stock the cable was touching the pipe a melting the rubber. I wire tied it away from the headpipe to the oil lines near the oil tank.
Old Oct 25, 1999 | 06:27 PM
86atc250r's Avatar
Sorry to keep posting this, but I keep finding more and more of these.
If it's a '00 model, check the throttle adjustment, all the '00 models I have been around and heard about only open the throttle slide and butterfly in the carb about 50~60% from the factory....
Note, this does not seem to apply to the '99 models
Free HP is good...
Gabe
'86ATC250R
'86ATC350X
'00TRX400EX
Old Oct 25, 1999 | 10:05 PM
mustang02's Avatar
Keep your 400 locked up so noone can take it like they did mine. It's been gone 2 weeks today
Old Oct 27, 1999 | 11:00 PM
MadMark's Avatar
Buy some aftermarket Handlebars, because the stock bars SUCK! Definately watch the rear brake pads. There isn't much to watch out for that i've seen. Drill 4 1" holes in the air box, and you'll get free HP.
exmotocrosser
Sep 26, 2015 08:18 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
