Help removing A arms on a 250R
Old Sep 18, 2001 | 05:50 PM
trx250Rob's Avatar
This is my first time taking a arms apart on my R. My question is, how do you get the arms to separate from the knuckle. I see the shop manual says you need a special tool but is there a work-around? I was wondering is you could just use a rubber mallot or a c-clamp? Do you need the tool to put it back together.
Old Sep 18, 2001 | 06:42 PM
KajunATVer's Avatar
I used a spreader fork that is used on car ball joints to get mine apart. To put them back together I just bolted them back.
Old Sep 18, 2001 | 08:12 PM
rhino99's Avatar
Just put a piece of wood or something on the bolt and hit it lightly with a hammer, thats how I did mine and it worked fine.
Old Sep 18, 2001 | 09:18 PM
letitsnow's Avatar
I put a piece of wood under the spindal and using a 2x4, hit the lower a-arm with a BIG hammer. Then I put the the piece of wood under the upper a-arm, and hit the spindal with a BIG hammer. When you do it this way, you have to place the wood in an area that won't bend or be damaged(obviously).
Old Sep 18, 2001 | 11:38 PM
crhye250r's Avatar
I would get a ball joint separator (available at your local auto parts store). It saves ALOT of time, and labor. I got one, and it cut my time by a long shot.
Old Sep 19, 2001 | 01:06 AM
trx250Rob's Avatar
Thanks guys, I tried hitting it with a hammer and wood, I couldn't hit it too hard since a busted my wrist about a week ago on my R. I'm going to have to get the ball joint separator. Thanks for the tips.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
slowgsxr97
Sep 8, 2015 04:37 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Canamaniac!
Sep 4, 2015 06:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
