250R : plastic switch? swingarm switch?
Old Oct 31, 1999 | 03:21 PM
RidE's Avatar
Would I be able to get '88/'89 plastic for my '86 250R? I'd like a light, but have yet to put it back on, because it looks better without one.
Another thing I'd like to do is get the '88/'89 shorter swingarm for my TRX, making it even more maneuverable and wheelies a snap.
As I understand, the 250R didn't go through any major chassis changes, allowing a person to make these switches. Am I right?
- 1986 Honda TRX250R, 1996 Kawasaki Mojave, 1998 Kawasaki Mojave, http://www.geocities.com/MotorCity/B...8090/home.html
Old Nov 1, 1999 | 10:57 AM
THEXOTIC1's Avatar
I have an 86 trx 250R and have put 89 plastics with light hood on my 86 they fit just fine. As for the swingarm it is shorter and alot lighter than an 86 swingarm. The 88-89 swingarm is made of aluminum as the 86 is made of steel the swingarms are interchangeable.
Alex
Old Nov 1, 1999 | 03:40 PM
WAYMOD's Avatar
You can easily change the plastic. Though the head light might be a little tricky.
The swing arm is a whole different question.
Yes it will fit. It will no longer have the lower back motor mounts which the motor needs (time to fabricate some). Plus the shock linkage is a differant length. The shock will work but it should be revalved for the new leverage it will incure.
Your best bet is to have a qualified machinest shorten your '86 swing arm (usually between $100 and $175) then rework your shock.
Good luck...
Waymod
PS the steel on will last much longer than the aluminium. The aluminium one start to crack up after a long and hard race series.
Old Nov 1, 1999 | 07:45 PM
RidE's Avatar
Cool, so it IS possible to actually turn your '86 into an '88/'89, right?
Speaking of the light, how do you actually get it to stay in place? Does it pop in, or what?
Thanks, this info is extremely helpful...
nachop
Feb 14, 2018 06:57 PM
chris7420
Jul 30, 2015 02:04 PM
1966F100
Jul 24, 2015 02:17 PM
95wolv
Jul 21, 2015 12:25 PM
CRamshaw777
Jul 18, 2015 05:46 PM
