400EX jetting, and cold starting questions.
Old Dec 29, 2001 | 02:35 PM
Mr350X's Avatar
Hey there people, I just bought a 99' 400EX. (previously bought a new 2001, but had to sell shortly after) This bike came from phoenix, 0-200 feet elevation. Now she lives at 5000+ feet in Prescott, AZ. It has a WB Eseries pipe, and possibly different jetting? It seems a little hesitant to start when cold. Could this be caused by different jetting? Especially if the bike was jetted for 0' elevation.
Any suggestions?
Also, about the fuel petcock, what position is RESERVE? pointing UP or DOWN? (I forgot, its been a while since I owned my other 400)
Thanks!
Old Dec 29, 2001 | 02:49 PM
imported_juggalo's Avatar
down is on, up is reserve. 400's are always resistant to start when their cold. changing the jetting might help however.
RotGutBottom's Avatar
If the bike is running at high elevation- you will need larger jetting size. I'm at 5500 feet in Utah- and run a 165 main jet. I'm running a little rich- so I'd reccomend dropping 1 jet size.
As for cold starting- the 400ex suffers... they ALL do. This should help:
1. Raise your idle speed.
2. Pump the gas 3 times
3. Crank the engine for 10 seconds.
If it doesn't start-... repeat steps 2 & 3 until it does.
I keep my quad in the garage with no insulation- so the engine is 30 degrees when I start it. I can usually have it going in less than 2 minutes.
hope that helps
Brian
toonces
Jun 30, 2015 11:19 AM
Bm400ex
Jun 22, 2015 09:16 AM
TJM
Jun 11, 2015 01:28 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
