400EX broken counterbalance shaft exploding out front of engine cases
Old Jan 5, 2002 | 08:19 AM
pudjumper's Avatar
I talked to Spark yesterday about a Carrillo rod that I bought from them. The rod did not come with a pin or bearings. Sparks reply was that 19 out of 20 motors that they built with a Carrillo did not need bearing or a pin, stockers would work fine. This is very uncomforting to hear. If i go to the expense of buying a $240 rod...damit I want new bearings and pin. Sparks went on to tell me that the only place on the planet to get rod bearing and a pin was to buy a complete X rod kit that cost $160. $400 seems kinda steep for a no hp gain. But then again, a hole in the motor would cost alot more. Anyone need a X rod without bearing and pin cheap?
Old Jan 5, 2002 | 02:18 PM
adamsmith's Avatar
The 400 does seem to have a problem with cracking cases. I thought it might only be modified motors, but it seems interesting that a stock motor has done it as well. I have seen 3 different motors with cracked cases mine, one at ECMX, and one on Ebay. I have also been told about 2 others. All of them were severely modified. I think that in alot of cases modifying a motor speeds up the inevitable, and in the case of the 400EXs counterbalancers and crank assemblies it seems as though their might be a problem.
Adam Smith
99 400EX
Old Jan 6, 2002 | 10:28 PM
wallsenterprises's Avatar
[img]i/expressions/face-icon-small-frown.gif[/img]
Points well taken, major modifications to engines (440's) may come with some unwanted side effects. However, this STOCK engine of mine should not explode like it had a stick of dynamite in the crankcase... :-(
I could see that if I had replaced the rev limiter and was always revving the crap out of it.
Like I said b4, I'll let everyone know how it turns out.....
Old Jan 7, 2002 | 06:54 PM
[img]i/expressions/face-icon-small-confused.gif[/img]
No news yet, I will call them tomorrow for a status.....
Old Jan 10, 2002 | 11:58 PM
  #15
[img]i/expressions/face-icon-small-sad.gif[/img]
Talked to the dealer and they'll be "squeezing it in" on the 16th. That's the soonest they could get to it since it is such a major job (yank the engine and split the cases completely). However, some of the case pieces have already been automatically removed..... :-(
Will give an update as soon as I know something....good news I hope....
Old Jan 11, 2002 | 03:40 AM
  #16
MXBUBS1's Avatar
Dudes, the motor is crap.....haha....I know, I have split the cases on mine several times.....clutch basket shatter, jumped time destroyed head, and most recently, the connecting rod broke!......to hell with honda, Im getting a yzf.....and as far as parts, tlcmotowarehouse.com is usually WAY far cheaper than anyone, just call Matt and name your price, he will usually give it to you for cheap cheap.....(boy, im glad i picked up this extra crank of ebay!)
Old Jan 14, 2002 | 06:47 PM
  #17
[img]i/expressions/face-icon-small-shocked.gif[/img]
Did your bike have alot of modifications? 440, bored, cammed, etc...etc...????
MikeyBoyesq
Nov 27, 2020 02:44 PM
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
txkevin
Sep 21, 2015 02:02 PM
Rooky
10
Jun 23, 2015 09:35 PM
250rCanCan
Aug 17, 1999 11:58 PM
