250EX Wheels fit Recon?
Will the 250EX/300EX/400EX front wheels fit the Recon? If not what is the offset/bolt pattern that will fit? I want to go from the stock front wheel size (11x5.5) to 10x5 (like on the 250EX/300EX/400EX). There are way more aftermarket tires available for the 10x5 size, but I need to get the wheels first. My stock wheels are dented, so I need to replace them anyway. If anyone has replaced their front wheels (on the Recon) what model did you go with?
Thanks,
Thanks,
Rears off the mentioned bikes will bolt right up, but sadly, the fronts won't. You may be able to get the fronts from company like douglas or ITP with the right bolt pattern in the 10x5 size. Or, you could replace the front brake's/spindles/hubs with those off a 250ex so you can use these wheels and have disk brakes.
