250r pukes
Old Feb 10, 2002 | 11:16 PM
Ward660R's Avatar
I kind of am getting in at the half way point of this project so the details are scetchy. Crank it up and it idles well. Blip the throttle twice and on the third time it boggs down and continues to bog. So we started it again held it open about 3/4 and out the pipe came what looked to be premix but more grey. Any help would be greatly appreciated.
Old Feb 11, 2002 | 10:36 AM
Dill's Avatar
you are probably having a carburetion problem. The float level in the carb could be set too high, your jetting could be way off, you could have a broken reed, or you could have a fouled spark plug.
Old Feb 11, 2002 | 02:24 PM
trx250Rob's Avatar
Amen to that. Keep in mind that to get a true reading opening the throttle wide in neutral is not a good indicator. You need to do plug chops to find out what is going on with your jetting. Do a search on this forum under jetting. You will find all the info you need.
Old Feb 11, 2002 | 06:38 PM
Ward660R's Avatar
Thanks, the reeds look good and the plug looks good. I haven't checked the float, but I will.
Old Feb 11, 2002 | 06:42 PM
trapperb1's Avatar
How's the air-flow "in"? Check out the filter and see if it's dirty. This can cause a lot of running problems and it's one that is easily overlooked.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
CRamshaw777
Jul 18, 2015 05:46 PM
