Split Fire
Old Feb 22, 2002 | 01:39 AM
RelicRacer's Avatar
My friend told me that a Split Fire spark plug will put pitts in your cylender. Is this true?
Old Feb 22, 2002 | 12:35 PM
trx250Rob's Avatar
I think I had read somewhere that this was a problems they used to have due to cheap metal used in the electrodes but it has been addressed. I wouldn't waste my time though, it numerous tests the only performance gain was due to reduced weight. The reduced weight of your wallet.
Old Feb 22, 2002 | 07:24 PM
BomBanshee's Avatar
I wouldnt buy those plugs from what ive heard on the forums there is no performance gain and they can cause your engine burn up.
Old Feb 22, 2002 | 08:44 PM
LotusPosition's Avatar
I don't know if it will pit your cylinder, I do know that my bikes have run much better on NGK's than Splitfires
Old Feb 22, 2002 | 09:45 PM
lonestarbanshee's Avatar
I have ran SplitFire and NGK's in my Shee since I've had it. Save your money, stick with NGK's. SplitFires, due to the dual electrode, will pit, or melt your piston.
Old Mar 2, 2002 | 04:37 AM
all4honda's Avatar
i dont think it will pit or melt your piston but I have never noticed any performance gains when using splitfires. Use a NGK DR8ES gapped at .024 or .026
Old Mar 2, 2002 | 04:40 AM
all4honda's Avatar
sorry but i just noticed you are from arizona you may want to go with a DR9ES this is a little colder plug it may be the choice if your bike tends to run hot.
Old Mar 2, 2002 | 09:59 AM
bermbanger400's Avatar
a friend of mine races a drag car he installed splitfires once to see if they would help heres what happen after only 2 passes his car started missing so he pulled the plugs to find that about half the electrode was gone on several plugs. where'd it go ? who knows but im sure it went into his motor which is not good.he runs NOS so that may have been why they did it.all i know is after seeing that i stay away from them.
ultangler
Nov 30, 2024 01:35 AM
mrtidy
Feb 3, 2016 05:00 PM
IMLN
Sep 28, 2015 03:32 PM
1ArmBandit
Sep 8, 2015 08:59 PM
Elkaholic
Sep 6, 2015 02:44 PM
