I just screwed up..Need help on 400EX
I was changing my oil as I always do, and went to torque the bolts on the oil filter and the right bolt broke. [img]i/expressions/face-icon-small-mad.gif[/img] I was torquing it per specs (7 ft. lbs). Broke low (deep inside) too. Now what? Can I still ride it? After putting in the oil I let it run for a bit and no oil came out of the hole. It secured quite well using just the left bolt (the shorter one). Where can I get the bolt on-line? Any part number out here? Any particular type of screw extractor? Thanks!
hey man u can order the bolt from a honda dealer as far as the problem at hand you'll need to back the snapped bolt out with an easy out which you can find at most auto part's store or just drill out the hole useing frist a small bite and keep going up in size's then you can get insert's that well pop into the hole and lock into place from there u just get out the tap and die set
Oct 10, 2015 10:20 AM
