air filter and jet kit?
Old Apr 3, 2002 | 04:17 PM
billygoat21's Avatar
I want to put an air filter and jet kit on my 2001 honda recon.
I'm looking at the UNI, TWIN AIR, and K&N air filters. Is there much differene between the three of them? Also, what jet kit should I use DYNOJET or K&N? Any help would be appeciated. Thanks!
Old Apr 3, 2002 | 08:58 PM
Quadfather's Avatar
From what I've heard, the Uni, and Twin filters will filter more dirt, but the K&N will flow more air. Most people will agree that you shouldn't run a K&N in dusty conditions. I would use an Outerwear on the K&N for sure. I run a K&N on days when it isn't dusty, and switch to a Uni Filter on the dusty days.
I can't give any info on a jet kit.
Old Apr 4, 2002 | 10:28 AM
Did you have to change your main jet at all? I was under the impression that if you switched to a less restrictive air filter that you needed to rejet since it would make your motor run lean.
Old Apr 4, 2002 | 03:34 PM
Quadfather's Avatar
I put a K&N on my Kodiak, and did not have to re-jet.
On my EX400, I put a different exhaust and a K&N, and had to re-jet, of course.
I would not think you would have to re-jet after switching just the filter.
Old Apr 4, 2002 | 03:59 PM
Thanks for the info.
Old Apr 5, 2002 | 09:14 AM
Dyno's Avatar
The K&N jet kit and the Dynojet kit are the same jet kit.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
