IMS 4.3 gallon gas tank for 400ex
I have this tank. You can ride forever!! When full, it will make the bike a bit front heavy though, so keep that in mind. If I am going to be doing lots of jumping, I do it on a tank that is at least half empty.
You will want to trim the bike plastic on the inside around where it butts up against tank at the top. There is a little lip on it, and just trim that off and the tank will fit way better (it's hard to explain, but you will see what I mean when you install it). Also, clean the tank VERY well before installing! Mine came with tons of little plastic pieces inside. This is a great mod! Don't hit the trail without it!!
