wondering if anybody has the 4x4 to 2x4 unlocker on their machine.....
Old Jun 22, 2002 | 11:13 PM
Dana67's Avatar
just wondering if anybody has the unlocker which allows you to shift from 4x4 to 2x4 and how you like it. i see now that warn has a release as well as high lifter. thanks for your info - dana
Old Jun 22, 2002 | 11:58 PM
TEXMud's Avatar
I have the HL Unlocker and love it. 2wd is pretty fun.
Old Jun 23, 2002 | 02:21 AM
kech22's Avatar
This past week, I ordered a Warn 424 Select (Part #WRN-62624) for my 1996 Honda 300 TRX 4X4. I should have it by Monday (6/24/02) via UPS. I will have it installed this next week and I will post of the results in the Honda Forum (how it was installed, any problems in installing, time, and how it works). If I like it, I will be ordering one for my 2001 Honda Rubicon. Cost of unit (62624) was $262.00 including shipping. Keep the faith and ride on......deer season is less than four months away.
Old Jun 24, 2002 | 12:50 AM
Fourtrax350's Avatar
I put Warn 424 Select on my 350 Friday night and put about 100 Km on it Saturday. What a differance, well worth the money. It is easy to put on, remove 4 bolts, pop out the old drive shaft, and pop in the new one.
Here are some Pics of it:
Warn 424
Warn 424
Old Jun 27, 2002 | 10:29 PM
Dana67's Avatar
how do you it shift? and where did you put the shifter? can you shift from 2wd to 4wd while moving? or 4wd to 2wd while moving? and finally, does it shift easy? thanks for your info - dana
Old Jun 27, 2002 | 10:31 PM
Dana67's Avatar
hey texmud, i sent you a note at your web site. was wondering if you read it? i was having problems with my rancher stalling while riding in some deep water. dana
Old Jun 28, 2002 | 02:24 PM
You shift by cable; I mounted it to the plastic on the left side just below the power outlet. There is a round disc with a button in the center. You pull out and it locks to shift to 2x4 push the button in to shift back to 4x4. You can shift on the fly in and out (I tried it at 30 km and you could not tell, no noise or jerk), although I would not do it if the rear wheels are spinning or under hard acceleration. You have to route the cable so there are no sharp bends and once done it shifts smooooth. Well worth the money.
Old Jul 2, 2002 | 11:26 PM
Dana67's Avatar
thanks for the info. sounds like something worth getting. i'll post my results when i get one. later - dana
Old Jul 6, 2002 | 09:52 PM
kech22's Avatar
I just posted information on installing and results of the Warn 424 Select on my 1996 Honda TRX300FW. See my post on July 6th (do a search on "Warn" in the Honda forums and look at "INSTALLED! Warn 424 Select on a Honda TRX300FW!" Great unit and my current post (7/6/02) provides more information and a couple of picture links. I will let you all know how the Warn 424 Select works on my 2001 Rubicon (when I purchase it - very soon - and install same). Great unit the Warn 424 Select, and highly recommend you getting one for your full time 4X4 Honda.
Old Jul 8, 2002 | 04:14 PM
JohnnyB's Avatar
Dana67, I had Warn's 424 installed on my 1992 Honda 300. Here are a couple of my observations: 1) FUN. It turned my little 300 into somewhat of a sporty machine to ride. I had allot of fun sliding around the trees on the trails. 2) In 2WD remember to use the front brake in conjunction with the rear brake. The rear brake alone only causes skidding. 3) Somewhat reduced steering effort, in my humble opinion the 300 had pretty light steering to begin with. 4) Spend some time thinking about were to mount the 424 handle (left side or right side). I find that the 424 is easier to engage when accelerating.
John
