250r won't idle
Old Jul 18, 2002 | 11:03 PM
chuck1221's Avatar
My friend has a 87' 250r that is completly stock other than a K@N filter w/ no airbox and a boysen rad valve. We have taken the carb apart and cleaned it and tried adjusting it. It stopped idling after he put the filter on. Anyone have any ideas on what to try.
-chuck
Old Jul 18, 2002 | 11:27 PM
lonestarbanshee's Avatar
Did he rejet it?
Old Jul 19, 2002 | 02:23 AM
chuck1221's Avatar
we re jetted the main jet but I don't think that has anything to do with the idling.
-chuck
Old Jul 19, 2002 | 09:09 AM
seven's Avatar
Try adjusting the air screw mixture, If your pilot is pretty close it should be 1 3/4 turns out. I run a 48 pilot at 2500ft.
Old Jul 19, 2002 | 11:27 AM
atc86r's Avatar
sometimes the filter are to oily. have you put in new plug/checked plug?
Old Jul 19, 2002 | 08:11 PM
chicneater's Avatar
fire the bike up and keep it running with the throttle, just enough to keep it running, while doing this, you or better yet, have a freind spray carb cleaner around all the intake boots to the carbs, if it rev's up on it's own, it's got a air leak, this will cause it not to idle also.....worth a shot, it's cheap.
Old Jul 20, 2002 | 04:15 AM
86trx250rhonda's Avatar
Mine did the same thing and mine was the pilot jest was to lean i richened it up and know it idles fine give that a try and see if it works.
Old Jul 20, 2002 | 03:06 PM
2fat4moto's Avatar
Yeap, it's the pilot!
Old Jul 20, 2002 | 03:31 PM
DesertBum's Avatar
Coil wire could be bad too
Scooter's Shop
23
Oct 22, 2015 07:04 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
