400ex best mods!
TURN YOUR GAS OFF.REMOVE YOUR AIR BOX CONNECTION TO THE CARB(LARGE BLACK HOSE)PUSH YOUR THROTTLE LEVER ALL THE WAY OPEN,TAKE A FLASHLIGHT AND LOOK INTO THE BACK OF THE CARB.IF YOU CAN SEE THE SLIDE HANGING DOWN AT ALL,THEN YOU ARE NOT GETTING FULL THROTTLE.IF YOU HAVE TO ADJUST IT,THE ADJUSTER IS UP ON THE THROTTLE LEVER CABLE. ADJUST IT OUT SO YOU WILL GET FULL THROTTLE.
What would happen if you just remove your end cap on the stock silencer? I have an e-series silencer that I had to send back to WB because the rear bracket broke. I ride every Wednesday evening so last night I just removed the endcap on the stock silencer. It obviously didn't run as good as the e-series but it did run better with the endcap off.
99' 400ex, WB e-series, Works Triple Rate, AC nerfs and bumber, Renthal bars, Dominators W/Douglas 1.90 all around
Sep 23, 2015 06:23 AM
