Lighting mods for older 4-Trax
Old Apr 10, 2000 | 11:59 PM
Deej's Avatar
I own an '87 350 4-Trax and would like to modify the lights. When the front rack is loaded the single bar mounted headlight is useless.
1. Has anyone added lighting to their 4-Trax and how did you do it?
2. The machine has 2 yellow Stanley running lights pointing forward. Has anyone turned these into headlights? Are clear lens' and brighter bulbs available?
Any suggestions or pictures would be appreciated. The wiring issues are not a problem for me. I am just looking for ideas for lights.
Thanks,
DJ
Old Apr 11, 2000 | 08:04 PM
frankd's Avatar
go to wal-mart or kmart and buy a set of 55 watt driveing lights thier about 20 dollars and a lot brighter than stock,and the bike will have no trouble running them
Old Apr 11, 2000 | 10:43 PM
MEDSKER's Avatar
Frankd has a good idea but i think I would go with somthing a little heavier duty but it depends on what you do with the quad. My Dad still has the 85 I grew up riding, they dont makem like that anymore.
Old Apr 11, 2000 | 11:29 PM
TxDoc2's Avatar
You may want to look at the new ATV lights from Warn. They are designed specifically for ATV applications. They are 21 watts and the cases are sealed to keep water out and have some kind of vent system to stop fogging up. If you are interested, let me know and I can scan the brochure and email it to you with the beam spread, etc.
Old Apr 11, 2000 | 11:39 PM
Deej's Avatar
Folks,
Thanks for all of the responses.
Tx2Doc, yes interested in the Warn setup and would appreciate the info. When you say 21 watts is that total or each? My assumption is each.
If you get a chance please send the info to johnson@comgate.com.
Thanks,
DJ
Old Apr 14, 2000 | 10:28 PM
justindeters1's Avatar
what does the old 350 look like.
Old Apr 14, 2000 | 10:32 PM
TxDoc2's Avatar
Yes, 21 watts each. I will scan the brochure tomorrow and email it to you. Look at www.Warn.com and select ATV products and select lights. If you want the scanned brochure, send me your email address at TxDoc2@aol.com
Old Apr 15, 2000 | 02:16 AM
Deej's Avatar
justindeters1,
The 350 looks "similar" to the Foreman of today. It is red, has 4 equal sized tires on it (24x9-11), has a solid axle front and rear. Has metal racks front and rear (they were an option that I added), has one handlebar mounted headlight, 2 body mounted yellow running lights in the front, 2 red in the rear, no guages of any sort.
DJ
Old Apr 15, 2000 | 04:42 PM
TxDoc2's Avatar
Deej-I scanned the brochure and put it in my Yahoo folder below.
Old Apr 15, 2000 | 10:28 PM
Deej's Avatar
TxDoc 2,
Thanks for doing that. I will have a look at it.
DJ
