300ex vs Warrior vs Mojave
Old Feb 27, 2003 | 10:51 PM
dirtboy034's Avatar
Default 300ex vs Warrior vs Mojave
I am trying to sell my Lakota and i want to know what one is the best one the 300ex, 250ex, mojave, warrior. So you can give me your thoughts on this
Old Feb 28, 2003 | 02:05 AM
ridered62's Avatar
cant ever go wrong with honda....ride red
Old Feb 28, 2003 | 02:49 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Of the bikes you mentioned, I have owned all but the Mojave. Skip the Warrior!! The design is to old. I rode one for years, and was never so happy as when I replaced it with a 400EX. The 250 is good, but the 300 is better (suspension, power, etc.).
Old Feb 28, 2003 | 09:21 AM
RideRed420's Avatar
i also say,
you cant go wrong with a honda....
Old Feb 28, 2003 | 05:25 PM
300exRiderJay's Avatar
I have a 300ex but the mojave has some advantages. More suspension travel, cheaper cost, easier reverse, and an almost unnoticable more amount of power. The 300ex is lighter, more soft or a ride, easier to wheelie, electric start, and a better front headlight(shines where you point it and is brighter). you could really go either way. The warrior has about much faster top speed at around 61, but is heavy and a little bit of a rough ride and more expensive. And correct me if i am wrong but i do not think the chasis has ever been changed so it is a little outdated. It is much more stable with its longer length and wider stance.
Old Feb 28, 2003 | 08:46 PM
dirtboy034's Avatar
the one thing i heard was that the mo with just a after market pipe would out run a 300ex but the 300 is still so much better looking
Old Feb 28, 2003 | 11:38 PM
CrAcKhEaD's Avatar
Go with the 300ex, honda is just so much better than kawasaki and the 300 is alot lighter. ive beaten piped and filtered mojaves with a piped 300
Old Mar 3, 2003 | 11:40 AM
RaceWarrior350's Avatar
Go with the warrior, it will kick the 300's butts...........
Old Mar 4, 2003 | 10:54 PM
Coyotechaser's Avatar
I wouldn't choose the Mojave because I always had to pull my friend to get his started. Then it would stall and I'd have to pull it again. The Mohave has kick start. But it does have liquid cooling. Top speed is supposed to be 55 mph. I would choose the 250EX if I was a beginner. The 250 EX would be reliable with the least amount of maintenance. It has an easy to use reverse, shaft drive and is semi-auto. Top speed is about 51 mph. The 300 EX is also reliable. It's light and agile on tight trails. I think that the top speed is 54/55 mph. The Warrior is the fastest stock with a top speed of about 61 mph. It's weight is heavier than the other 3 and you can feel it. It is supposed to be about the same weight
as my Recon but it always felt heavier. My warrior was also reliable. My choice of the 4 quads would be
between Warrior and the 300 EX. It's hard because I like the Warrior. But I believe that the 300 EX would be best. I'd still miss the top speed of the Warrior. But top speed doesn't = best.
Old Mar 5, 2003 | 01:20 PM
dirtboy034's Avatar
i actully ment the 250x not the 250ex sorry about that i no they are old but my friend had one and said it was graet
