Was dismayed and perplexed!!!
Old Apr 19, 2000 | 09:47 AM
bigmanm's Avatar
I just took apart my motor the other day to put a new head gasket in. When i put it all back together it would not start. I was positive i had all the timing right. So I took the motor back out and took the hole thing back apart again and still could not find out what was wrong. I then started thinkin that maybe it did not have enough compression to start. So I checked the valves and noticed the exhaust valve was never going completely closed because it was adjusted so tight. I then adjusted it and put it all back together and it started on the first pull. It ran before I took it apart. Do you think that this valve was like this before I took it apart but maybe just not as tight.
Old Apr 19, 2000 | 10:01 AM
hotdoger's Avatar
When you put it back together you forgot to adjust it properly
summerjack
Nov 22, 2011 08:05 AM
zackman1801
Oct 3, 2011 07:05 PM
ArcticCat4ever
Jan 27, 2010 03:21 PM
22222
Where to Ride
May 10, 2006 10:12 AM
