POLISHING Side Covers
Old Mar 21, 2003 | 01:05 PM
mojave300ex's Avatar
Default POLISHING Side Covers
My cousin and I are trying to polish his side covers on his 400ex. Problem is we can't find stripper strong enough to remove the paint. Is there a miracle strippper or another way?? Thanks
Old Mar 21, 2003 | 03:39 PM
DaBeechMan's Avatar
Sand blast it. If you dont want the ill effects of sandblasting they make a gun that shoots walnuts that takes off the paint, but doesnt make the surface quiet so coarse.
Old Mar 21, 2003 | 05:00 PM
KGB's Avatar
KGB
Or glass bead it (thats what I did), a machine shop should be able to do it for $20 or so
Old Mar 21, 2003 | 08:18 PM
That's what I thought, I'll have to do a lot of sanding with different grits of paper.
Old Mar 21, 2003 | 11:19 PM
dirtgirl's Avatar
If you blast your parts though they will not polish up that easily... you will still have to do quite a bit of sanding to get them smooth enough to polish....
Old Mar 22, 2003 | 12:33 AM
Yes, my sand blaster leaves a rough surface. I have done this several times when I find an old aluminum part that is painted and I decided to polish it. I blast all the paint off then smooth my sandblasted surface with brown scotch brite, then red, next I use a rough steel wool, and finally a fine steel wool (#6). Now I start buffing with a heavy ruge on the bench grinder, continue the process and finish up the hard to reach by hand.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
