750 atv
You probably should use an LT 500 zilla frame
it is the biggest quad frame (I think) it will give you something to work with. It is a
wide quad so it should give you some stability I don't recommend riding your 750 in the trails it will bottom out and be hard to control (because of its weight) on tight
corners Hope this helps
Boy don't ever insult me like that again. I thought you ment stock. Yes I have seen the Banshee's and 250R's and Qaudzilla's with large engines. I was also making a joke about it when I said that so I think you need to think before you post crap like that next time. They will never make a stock bike with that many cc's at a reasonable price ever. That was what I was stating because I figured you ment stock. I also have the brains to do it so don't ever insult anyone like that again.
