250x racer?
would a 250x make a good quad to start out with in racing? i am thinking of doing some mx in a year or so. also, i would like to know what are some good mods i can make to it to keep up with the big boys, money is not an issue. any suggestions will be helpful.
I feel that the way I set up my X is a good MXer and also a setup that wont hurt your wallet too bad. Here's what I have....
Powroll 288 kit, head milled .006, 1mm oversize valves, ported head, stiffer valve springs with titanium retainers, billet cam, hardweld rocker arms, powroll supertrapp exhaust, 350X intake boot, FST oil cooler, UNI air filter, Works Shocks all the way around, Durablue Eliminator Axle, RAD Dual Row bearing carrier, 400EX tires, SBS brake pads, 250R A-Arms, Steel braided brake lines (not on yet but will have shortly), Maier race cut black plastic, N-Style graphics kit, DG Nerfs (polished)
I've got some other do dads and gadgets on it but I can't think of everything off the top of my head.
If you like the small bike that the 250x has to offer. . .you could do liek i did. . I put the 350x motor in mine. . .then there are tons of things motor wise you can do .. .especially if money is no option. . good luck
Sep 30, 2015 01:37 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
