Cooling fan transplant
Old May 6, 2003 | 02:41 AM
Jerms's Avatar
Default Cooling fan transplant
Does anyone know if an electric cooling fan from a Foreman 450 would work/fit on a 300 4x4? Is there enough room under the front to mount it properly?
Thanks,
JC
Old May 6, 2003 | 08:16 AM
yellowexracer's Avatar
I just installed 2 little plastic fans right in front of the oil cooler and they work great
Old May 9, 2003 | 09:04 PM
Just an update on those fans, I was out for a while and they seem to keep it running alot cooler!
Old May 9, 2003 | 10:54 PM
Jerms's Avatar
Thanks for the update. BTW, what sort of fans did you use? Where'd you get them?
JC
Old May 10, 2003 | 11:37 AM
I'm not sure of the brand, i bought then for $4 each at princess auto
Old May 10, 2003 | 01:41 PM
Jerms's Avatar
If they're that cheap then they'd probably not hold up to mud and water if you do much of that kind of riding, would they?
Old May 10, 2003 | 03:56 PM
They were regular $9. They should hold up because their brushless and I had one on my old suzuki and it worked fine in the water and mud. Also there mounted up under the fender and on my suzuki it was down by the engine in the open.
Old May 10, 2003 | 04:05 PM
Jerms's Avatar
Cool (er, no pun intended).[img]i/expressions/face-icon-small-happy.gif[/img] Is there a particular brand and/or model on these fans you're using?
JC
Old May 10, 2003 | 04:14 PM
Nope there's no brand name on them, i think they were just surplus stuff.
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
alzgarvin
Sep 11, 2015 08:53 AM
lancemll88
Sep 5, 2015 03:16 AM
