Which is the best exhaust for the 400 EX?
Old May 5, 2000 | 09:12 AM
JAKOOL's Avatar
Air is right, the best pipe will depend on the mods you are planning for your bike.
Old May 7, 2000 | 10:12 PM
wcy2k400ex's Avatar
Well, I have a K&N filter with an Outerwears already. I also plan to increase the main jet size, but other than that, I will probably keep it stock. What should I get as far as exhaust systems go?
Old May 8, 2000 | 01:47 AM
Air's Avatar
Air
Big Gun with a quiet core spark arrestor. The best pipe for stock . I makes alot of torque.
What you are doing is basicall stock.
99 426ex , Web Cam, FCR carb w/ twist, CT revlimiter, DMC exhaust, XCT's ,K&N, One kit, Renthal bars, DG nerfs, Armidillo Swingarm plate, 8 paddle Haulers
http://www.trxoutlawz.com/
Old May 8, 2000 | 01:51 AM
Air's Avatar
Air
Get a Dirt Wheels and browse through it and start calling .Prices will vary. I purchased it through Factory team Racing.
Old May 8, 2000 | 04:30 PM
  #15
quadman440's Avatar
Go to ctracing.coom and look at there pipe. it is a great pipe for a moded enge with the full race one and for stock one go with the mid range pipe. So far it has been a great pipe, and has no problems so far. Plus i had a DMC. It is a good pipe but you lose alot of bottom end. With the ct u don't and still have the top end too.
400ex, 450/451 web cam, CT pipe, CT REV BOX, VALVE SPRINGS, 401 over bore and a 10 to 1 compression piston, K&N, Dyno jet kit.
Old May 9, 2000 | 07:58 PM
  #16
wcy2k400ex's Avatar
I have looked at the White Bros. E-Series, Big Gun, and CT Racing systems. I can't decide which one is the best. What are the upsides and downsides of these 3 systems? I would like more bottom to mid-range power more than mid-range to top-end power. Which would be the best for this? I also am going to keep my engine fairly stock, and don't want and ear drum busting exhaust system. Which would be the best one? Please help.
Old May 9, 2000 | 07:59 PM
  #17
wcy2k400ex's Avatar
Old May 9, 2000 | 11:10 PM
  #18
EXtreme-'s Avatar
The homework is already done for you....GT Thunder dyno charts...400ex Shootout
Old May 10, 2000 | 08:36 PM
  #19
Air's Avatar
Air
The one problem with this shootout is it compares a prototype Big Gun with production pipes. They are always looking at ways to improve the Big Gun.
Not just getting it close then moving on to another project. For a stock engine a Big Gun is a big improvement over stock. Most of the other exhaust systems make more high end HP though. I personally prefer the DMC which makes more HP than the shootouts "winner" the E series.
Old May 11, 2000 | 02:14 AM
  #20
hakmazter's Avatar
keep the stock pipe and go elsewhere for power mods. it is embarrassing that the pipes make so little difference on a four stroke. I will put money on mine in a race with a stock pipe, port matching, and a xr400 head gasket. Cost me $25.00 and I walked away from a stocker with a powercore IV2, but I had the airtools to grind on my head. I will get a cam soon and kill people like you guys. Then a 426 piston to top it all off. The factory pipe works too well for the massive increase in noise.
