Plow ??
I just bought a new Kodiak 450 and had a Cycle country plow with manuel lift installed on it. When itwas installed they have a strap on the front that from what I gather adjusts the height that the plow goes when I pull it up. Any helpfull hints on how it should be adjusted and when (or what position the plow ahould be in when I adjsut it. Unfortunatley I did not ask all the right questions when I picked it up.
Tracker;
That strap wraps around your front bumper,now with that said there should be an "L" shaped bracket
in which this strap attaches to mine has three holes. According to my instruct. the hole farthest away from
the atv is recommenedbut, the one closest to the atv is the easiest to lift.to this a threaded rod goe's down
the middle of the tube runners which attaches to your manual hand lift, by adjusting this rod in or out this
is what gives you the lift on your plow along w/the tension non your strap. In the blade down mode strap should
just taut not tight, if it's a new setup you might have to adjust a couple of times, because strap stretches.
kampswas
Sep 23, 2015 05:05 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
