Hunting, Trapping, Game Management Discuss Bow and Fire Arm Hunting.
Plotmaster W/330 Magnum Question.
Old May 24, 2006 | 09:21 AM
FamilyGuy's Avatar
Default Plotmaster W/330 Magnum Question.
I've had two farmers back out at the last minute plowing my field this spring. Getting tired of relying on others. Question is, does anyone own a plotmaster and what do you tow it with and two, those that do own one,will my wife's 04 330 Magnum tow it?
The website indicates that a 300 cc or larger is required, any inputs from anyone?
"IF YOU WANT IT DONE RIGHT, DO IT YOURSELF" seems to apply for me on this topic! :-)
Old May 28, 2006 | 11:35 AM
Reb2's Avatar
I haven't used the plotmaster so this response is based on my experience with other systems. The 330 will be marginal power wise but will probably pull it. I suspect the main problems you will have will be overheating the engine due to pulling a lot at a slow speed. Also you will probably have belt heating problems, again pulling a lot at a slow speed. I don't know what the plotmaster weights but you will probably have to add weight to the ATV to overcome the weight of the plotmaster and the drag of the disks, S-tines and drag screen which will add to the above problems.
Old May 29, 2006 | 12:23 AM
hikuntryslim's Avatar
why not go with the srambler ?
Gwolf228
Feb 18, 2017 01:36 AM
bigred20653
Oct 2, 2015 10:05 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Bigtwin700
Sep 9, 2015 09:32 AM
Sep 9, 2015 06:57 AM
