Hunting, Trapping, Game Management Discuss Bow and Fire Arm Hunting.
Atv with high torque at low speeds?
Old Mar 26, 2003 | 11:21 PM
chuckinnc's Avatar
Default Atv with high torque at low speeds?
I need a new 4x4 atv, the large ones look good but do they pull good at low speeds or just have better top end/speed? What would be
a good farming/hunting Atv with good low speed torque?
Old Mar 26, 2003 | 11:28 PM
Arctic330's Avatar
you need an Arctic Cat. they are all around great except for top speed.
the only thing is the stock tires would have to be changed but get the dealer to do it before you buy it.
make it part of the deal.
recomend titan 589's
Old Mar 26, 2003 | 11:39 PM
springdrl's Avatar
If you want solid torque at low speeds with less maintenance, I would go with the conventional auto-clutch with manual shift. Most of the automatics make use of a centrifugal drive belt mechanism that requires a higher rpm to match the torque of a multi-plate auto-clutch. Of course you'll have to change gears manually. However, clutch plates will take a lot more beating before needing replacement than a belt-driven auto.
Automatics are great if you're looking for the most convenient ride. It sounds as if you might be looking for more of the tractor-type performance of the well-proven and durable auto-clutch.
Let me add too that I would put the long term, high torque performance of a 400cc auto-clutch against the largest automatic that you can buy.
Old Mar 27, 2003 | 12:08 AM
carver's Avatar
go with the larger displacment for torque. most big quads these days have a good combo of low end grunt combined with very respectable top end. buy a sportsman, you'll never be sorry!
Old Mar 27, 2003 | 12:14 AM
stubblejumper's Avatar
The rubicon will give you an automatic without a belt drive.They have low range and pull very strong at low rpm.
Old Mar 27, 2003 | 12:22 AM
AoneC's Avatar
The Yamaha BIG BEAR has a super low first gear for pulling, and push button 4wheel drive with the manual shift auto/clutch.
Old Apr 11, 2003 | 11:12 PM
Raptorx44's Avatar
I will have to agree on the Big Bear that first gear could pull a house down!!
Old Apr 12, 2003 | 01:15 AM
toytech's Avatar
i agree with the big bear, but also have a good look at the honda formans, 450 or 400. even with no low range they have tons of low end torqe. they will spin out before they power out!
Old Apr 12, 2003 | 09:56 PM
hammer4's Avatar
Suzuki King Quad, or a Bombardier Traxter.
Old Apr 12, 2003 | 11:49 PM
2000IAWarrior's Avatar
rubicon
