Help!!!
Old Jan 12, 2012 | 09:34 PM
1929AAtimer's Avatar
Default Help!!!
I just bought a 01 Yamaha Warrior, when I get it home I realized the rear rotor was warped, the parking brake was out of adjustment, and the caliper was seized... I bought a new rotor and caliper with the E- brake block off plate... I need to remove the hub, the nut is off but the hub doesn't seem to want to come off the axle there is a little bit of corrosion on the splines, is there a trick I'm not thinking of to get this hub off the axle? I'm used to useing a little brute force but concerned about doing more harm than good...
Old Jan 13, 2012 | 07:43 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
You might want to post this over in the Yamaha section to get a quicker, better answer.
Old Jan 13, 2012 | 08:46 AM
Old Jan 16, 2012 | 08:28 AM
BioWare's Avatar
Toxic Ryder
Welcome
