05 kawasaki prarie 360 2wd with idle problems plz help!!
Old May 13, 2014 | 10:46 AM
Chillidog94's Avatar
Default 05 kawasaki prarie 360 2wd with idle problems plz help!!
Ive had my o5 prarie since 2006 it'd never been driven and still has the original tires at 700 hrs , I've re jetted the carburetor and loosened the valves but it still has one problem, when I go for a two or three hour ride and give it a few breaks it will idle really high even if I take the idle screw down dangerously low it still idles high.
Old May 9, 2015 | 06:50 PM
Default Kawasaki prairie 360 anomaly of problems
Hello, when i get on my prarie 360 and put it in high gear it idles very high and i have to rev the engine a few times to get it to go, and once I've rode it for an hour or two it will idle so high that I can coast on flat surface for seven seconds and my gas tank is half empty and it may sputter as if the choke is on.
- I've jetted the carbs
- I put a moose racing belt on
with out racing clutch.
- I ride it for 3 or four hours at a time in the summer and have had the same battery since 2011.
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
ranvette
Jul 4, 2015 06:13 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
mattlvsbball
Apr 24, 2000 06:54 PM
