groovie1955
Old Jul 12, 2016 | 10:52 PM
Originally Posted by groovie1955
But the water pump impellar will turn on the shaft withhot the motor running,is this normal...
No.. I answered on your other post. Don't post in different spots on the same thing as it causes confusion.
Old Jul 16, 2016 | 12:27 PM
groovie1955's Avatar
Big Daddy Mike
Mr.Old Polaris Tech.thanks for all you're help.I think I finally got it,I must not have tightened the impellor nut enough because the impellor was locking against the outer housing and would'nt evening turning.So I added another washer between the nut and impellor and used blue locktight on the nut.But thx. again.
Old Jul 16, 2016 | 12:30 PM
Big Daddy Mike
Mr.Old Polaris Tech.thanks for all you're help.I think I finally got it,I must not have tightened the impeller nut enough because the impeller was locking against the outer housing and would'nt evening turning.So I added another washer between the nut and impeller and used blue locktight on the nut.But thx. again.
Old Jul 17, 2016 | 04:24 AM
That's fine adding another small washer in front of the nut.. The main thing is to make sure you still have the small seal washer behind the impeller. If you don't that may be the reason you've had to add a washer. This small washer helps protect the w/pump seal from seeping and wear from the impeller. Item#5.
Old Jul 17, 2016 | 12:47 PM
  #15
Big Daddy Mike
I did and thanks again...
clayh
Jul 7, 2016 10:42 AM
Tom Mendenhall
Jul 4, 2016 04:59 PM
Jun 29, 2016 02:18 PM
Croot23
Utility ATVs
Jun 20, 2016 05:38 PM
Daubs
Jun 15, 2016 09:24 PM
