450 foreman headlights not working? Help?
Old Oct 10, 2016 | 11:40 AM
Ross.B's Avatar
Default 450 foreman headlights not working? Help?
Hey guys I recently bought a Honda 450 foreman and have ran into a problem with it. When I first bought the bike all headlights worked good hi and low beam but now the two small headlights stopped working. They randomly stopped working at the same time on both high and low beam. What do I check to fix it? Is there a certain fuse I could check? The big headlight still works (runs off different switch) and the tail lights work too. Maybe a ground needs to be checked? Where would it be located I'm not a mechanic.
Old Oct 10, 2016 | 01:04 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Check out the Honda section, lots of good tips and info in there.
Old Oct 11, 2016 | 07:46 AM
hydrex's Avatar
If you don't have one, you might download a parts and service manual. Might try I found them for my Arctic Cats there. If you have the owners manual, should show where the fuses are. Might want to take gas tank off and look for chafed wires around the steering column, too. Get a "multimeter" or a wire tester to check wire continuity.
Old Oct 11, 2016 | 11:37 AM
hydrex's Avatar
Check K&T's Parts House web site for downloads.
Old Oct 22, 2019 | 10:34 PM
Jared Story's Avatar
Did you ever figure this out? I am having the same issue
Aug 4, 2016 03:39 PM
Kord02
Aug 3, 2016 04:31 PM
Degoragon
Aug 3, 2016 09:03 AM
ThatLambethDude
Aug 1, 2016 06:42 PM
bradleyheathhays
Jul 24, 2016 03:55 PM
