Hi from NY
Old May 1, 2017 | 05:19 PM
legns's Avatar
Default Hi from NY
Hi from long island. I found this forum because I recently acquired a 1985 Suzuki lt230s. My first 4 wheeler but I have a few Honda trikes. What brought me here is my problem with the carb for the 230s. It looks like I will need to replace it mainly because I can not get it apart to rebuild it. The guy I bought it from lived on the water and the salt in the air has seized it. now here is my problem what do I replace it with. I can not find a vm26ss carb anywhere. Any help would be greatly appreciated. Thank You
Old May 1, 2017 | 05:44 PM
Scooter86's Avatar
Knows Old ATV Questions!
Some vice grips on those soft brass float screws should get them off. Then tap the bowl with a rubber mallet. Not sure what other carbs may mount up, but I would be surprised if there isn't a close replacement from mikuni.
Old May 1, 2017 | 06:03 PM
legns's Avatar
I wish I could get to that point the guy had it in his garage for the last 15 years living on the ocean. The salt in the air has really frozen it. I can't even get the cap off to pull the plunger out. all the set screws, choke, winter/summer thing and scews that hold it together frozen. I have tried every oil/ nut buster/anti freeze stuff I can find and nothing.
Old May 1, 2017 | 08:04 PM
Scooter86's Avatar
Amazon Amazon
A quick Google search for mikuni vm26 showed a bunch of hits...
Old May 1, 2017 | 08:36 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Old May 1, 2017 | 09:45 PM
legns's Avatar
Originally Posted by Scooter86
https://www.amazon.com/Mikuni-Round-.../dp/B0068C1P9Y
Yes I have seen those but the specs are off from the stock carb as per the clymers book. So i'm a little skeptical to spend that kind of money and I don't know if it will work. I also read that the vm26 is not the same as the vm26ss. So I am trying to clarify that as well and thank you for the help.
legns's Avatar
Old May 2, 2017 | 07:38 AM
Scooter86's Avatar
As long as the od of the input and output of the carb fit the intake boots, it should be good to go. Generally you can get away with a small range of sizes like a vm28 may work although it could suffer a little power loss at lower rpm vs more potential on top. Vice versa on a vm24. If the machine has stock intake and exhaust starting with stock jet sizes should get you pretty close if using another 26mm carb. I don't remember the old quads port carb being anything crazy, choke on the carb, pretty standard throttle cable, round slide. If it really concerns you, why not drop a line to mikuni and see what they recommend as a replacement if the SS is out of production?
Old May 2, 2017 | 12:09 PM
Welcome.
Old May 2, 2017 | 04:10 PM
legns's Avatar
Thanks. The vm26-606 seems to be closest to the original with the jetting and design being a little different. If it was a 20-30 dollar carb I would just buy it but it being 70-100+ dollars I don't want to trial and error at those prices. Now regarding mikuni I don't know which one to contact I did a search and three websites saying that they are the company came up. I may have to call all three
