Hello to all. thank you for any help or advice u may give.
Old Jul 19, 2017 | 10:42 PM
zabortnick's Avatar
Default Hello to all. thank you for any help or advice u may give.
trying to fix Little 90cc four stroke. it wont crank over unless i bypass the starter button and has no spark when i do. i have tested the button and kill switch but am unfamiliar with the wire colors so not sure whats what or why no power to starter button or ignition ststem. purchased a new cdi module and no change, i SUSPeCT the key switch but not sure on the wire colors so not sure if its working proper.
Old Jul 20, 2017 | 06:06 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Check out the brand section for your model. It will help you get the correct answer faster.
Old Jul 20, 2017 | 09:27 AM
Welcome
Old Jul 21, 2017 | 08:19 PM
dbj216's Avatar
Back Country Explorer
Hi from Colorado. You are correct to introduce yourself here in this subcategory for new members. Your technical question will find more responses under the brand discussion category, and then the make of your 90cc machine. Give that a try, I'll bet someone can help you.
There aren't many of us that watch this new member category. I do because I'm not as experienced in solving technical problems with older ATVs.
David
