1986 bayou 300 carburetor
Old Aug 27, 2017 | 12:37 PM
michaelperkins69's Avatar
Default 1986 bayou 300 carburetor
Hi I need help I'm having carburetor issues I couldn't get my bayou to start and run so I bought a carburetor and installed it but it started pouring fuel out of the bowl drain without stopping until I turned the fuel off I noticed the fuel line was attached to the top inlet but on the old one it was attached to the bottom one. If I attach it to the bottom one it won't run but if I attach it to the top one it runs but pours fuel does anyone know what's going on with it?
Old Aug 27, 2017 | 01:06 PM
Think you have the fuel going to the atmospheric vent on top.This should just be an open air vent tube or either a vacuum line going to a fuel pump if so equipped.The bottom nipple should be the fuel inlet. Take the carb bowl off and see if trash is stopping fuel from entering though the needle and seat or the float is stuck. If this is one of those aftermarket Chinese carbs,a lot of people have had to take them apart and blow out all the openings and jets. P.S. Welcome to the forums..
Old Aug 27, 2017 | 01:15 PM
Thank you for the information it is a after market one I figured it wouldn't hurt the wallet to try one.i was wondering why they had the fuel line attached to the top inlet. I'll let you know if it works when I get a chance to look at it it may be Tuesday that's when I'm off next.
Old Aug 31, 2017 | 12:05 PM
Default Bayou Carburetor
Hi update got it running but still hard to get started when cold any advice plus I swapped engines for one that had been sitting awhile and it was froze up I got it freed drained the oil no metal changed the oil add sea foam ran it a little bit drained the oil still no metal but makes a kinda hi pitch sound the more you give it throttle the louder it gets any thoughts thanks in advance
