hard shift
Old Jun 3, 2003 | 08:10 AM
FisherDude's Avatar
Default hard shift
Guys:
My 03 Prairie 650 dont shift like it did when it was new[img]i/expressions/face-icon-small-disgusted.gif[/img] When you move the **** to high sometimes I have to give if a tad throtle to get it in gear. Is there an adjustment or something I can do for this problem? Thanks, Bob
Old Jun 3, 2003 | 08:53 AM
trx450's Avatar
Default hard shift
Shift linkage adjustment time
Old Jun 3, 2003 | 10:11 AM
jwkawi's Avatar
Default hard shift
i thought that too when my prairie did that. but it ended up being a simple raising of the idle and it's cured.
Old Jun 3, 2003 | 10:44 AM
trx450's Avatar
Default hard shift
jw-- not familiar with RAISING the idle to get better shifting. I have have to LOWER it, though. Oh well, that is easy enough to try. It'll take 3 secs. to do it! Try the idle speed adjustment first.
Old Jun 3, 2003 | 11:42 AM
Pray4a650's Avatar
Default hard shift
The first week I had the bike, I had the same problem. The dealer raised the idle.
Now the bike shifts like a charm.
Old Jun 3, 2003 | 07:34 PM
Megadav's Avatar
Default hard shift
my experience has been:
if it grinds goin into gear- lower idle
if it wont go withouth a little throttle - raise idle
hope this helps.
Old Jun 3, 2003 | 08:58 PM
Kawi650's Avatar
Default hard shift
The idle can be too high and too low and both would effect the shifting. I would check for slippage in low or reverse to see if you need to adjust your linkage shifter
Old Jun 4, 2003 | 01:32 AM
FisherDude's Avatar
Default hard shift
Jason:
Slippage? belt Slippage? What am I looking for? I turned up the idle and it helped some but but not like when it was new. thanks for the help, you guys sure know your stuff. Bob[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 4, 2003 | 09:01 AM
Pray4a650's Avatar
Default hard shift
What kawi650 is referring as slippage is if you are in low gear, and you hear a "knocking" or "grinding" sound from your sub transmission when you go down a hill or when you slow down. If so you need a shift linkage adjustment.
However, FisherDude, this does not seem to be you problem.
Noroc has this adjusment on his help page.
Old Jun 4, 2003 | 06:18 PM
Kawi650's Avatar
Default hard shift
I guess it could be discribed as jumping out of gear too. Also some 650's need their gear shifter grinded down a bit but you should be ok on and 03 I think it's only on some 02s.
